Going thru my MREs I noticed some cases were going on 10 years old, so thought the older ones need to be consumed. Then I found a case of TOTMs and wondering about the date.
Most posts mention the code as a 4 digit number, but mine (on the case) shows 15106, which I take to mean April 16 of 2015.
EDIT to ask, is there a shelf life for the heaters? The only use I have for them is using in soda bottles, but if they don't work after 10 -15 years, I will probably discard them.
Date code TOTM
- Amelieee1
- eBay name: Amelieee_1
Re: Date code TOTM
Sometimes they work if you give them a shot of salt. sometimes not. hit and miss as they get oldIcon wrote: Sun Aug 07, 2022 3:48 pm Going thru my MREs I noticed some cases were going on 10 years old, so thought the older ones need to be consumed. Then I found a case of TOTMs and wondering about the date.
- Militaryration_guy
Re: Date code TOTM
I've had Sopacko Surepak heaters that are 6 years old and take off without salt but I've had 1 year old heaters that are duds even with salt.Amelieee1 wrote: Sun Aug 07, 2022 8:50 pmSometimes they work if you give them a shot of salt. sometimes not. hit and miss as they get oldIcon wrote: Sun Aug 07, 2022 3:48 pm Going thru my MREs I noticed some cases were going on 10 years old, so thought the older ones need to be consumed. Then I found a case of TOTMs and wondering about the date.
A random hillbilly guy intrested in in military rations from across the world
- Amelieee1
Re: Date code TOTM
For that i would say you are using them wrong. Dont add too much water and make sure to knead the water into the pads. dont forget it also needs oxygen to workMilitaryration_guy wrote: Mon Aug 08, 2022 9:35 amI've had Sopacko Surepak heaters that are 6 years old and take off without salt but I've had 1 year old heaters that are duds even with salt.Amelieee1 wrote: Sun Aug 07, 2022 8:50 pmSometimes they work if you give them a shot of salt. sometimes not. hit and miss as they get oldIcon wrote: Sun Aug 07, 2022 3:48 pm Going thru my MREs I noticed some cases were going on 10 years old, so thought the older ones need to be consumed. Then I found a case of TOTMs and wondering about the date.
Re: Date code TOTM
Check out this:Icon wrote: Sun Aug 07, 2022 3:48 pm EDIT to ask, is there a shelf life for the heaters? The only use I have for them is using in soda bottles, but if they don't work after 10 -15 years, I will probably discard them.
There never was a 5 digit date code. So 15106 could either be 1510 - without the 6 but there isn´t a 510th day of a year so you are right, it suppose to be 5106 what was April 16, 2015.Icon wrote: Sun Aug 07, 2022 3:48 pm Most posts mention the code as a 4 digit number, but mine (on the case) shows 15106, which I take to mean April 16 of 2015.
Re: Date code TOTM
So perhaps besides adding water to the fill line, laying the hater on it's side quickly to let water hit all the pockets and flip the top shut that I should instead blow air into it for a second, I used to put the pouches in the heater but now I put them outside the heater and flip/ rotate them.Amelieee1 wrote: Mon Aug 08, 2022 8:28 pmFor that i would say you are using them wrong. Dont add too much water and make sure to knead the water into the pads. dont forget it also needs oxygen to workMilitaryration_guy wrote: Mon Aug 08, 2022 9:35 amI've had Sopacko Surepak heaters that are 6 years old and take off without salt but I've had 1 year old heaters that are duds even with salt.Amelieee1 wrote: Sun Aug 07, 2022 8:50 pm
Re: Date code TOTM
Interesting video.. thanks.. do you know if the silver bag he had was mylar, or something else???housil wrote: Tue Aug 09, 2022 7:01 amCheck out this:Icon wrote: Sun Aug 07, 2022 3:48 pm EDIT to ask, is there a shelf life for the heaters? The only use I have for them is using in soda bottles, but if they don't work after 10 -15 years, I will probably discard them.
Re: Date code TOTM
You can ask RockyRaab, he is a member at forums:Icon wrote: Thu Aug 11, 2022 9:08 pm Interesting video.. thanks.. do you know if the silver bag he had was mylar, or something else???
memberlist.php?mode=viewprofile&u=1714
Re: Date code TOTM
Intresting vid , thanks for sharing.
